Cisco RV router series question
Cisco eng
I have a question. We sell alot of cisco 800 routers. Now for some customers we have they are to expensive.
So we were thinking about the RV series, but I can't find any good routing performance specifications for these routers.
If I go to:
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
I can see alot of performance details of the cisco products but the RV router series is not there.
Can anyone tell me what the performance specifications of these routers are? (packets per seconds, mbps data throughput)
Thanks in advance,
Tom
you can also view the data at smallnetbuilder. There are many different performance test run
http://www.smallnetbuilder.com/lanwan/router-charts/view
Te-Kai Liu
Level 7
Level 7
There is one performance report done by a third party on the performance of RV082.
http://int.xscale-freak.com/XSDoc/IXP4xx/tolly_204132.pdf
Thanks tekliu,
But those only show RV082. I would really like the specs for all of them.
Doesn't Cisco have some kind of list/sheet with the speeds and throughput etc.?
Thanks doishi that helped alot, no packets per second though but good enough.
