Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
1257
Highlighted
Beginner
cisco RV042 Dual Wan issue for sip trunk
hi
here is my setup :
I am using the CISCO RV042 router to connect my phone system to a Sip trunk provider router and to extend my Lan segments so the phone system have internet access.i need it this way because i cant put 2 default gateway in my phone system so the cisco Rv042 is the default gateway of the phone system and i use port fowarding of the UDP ports 5060 to point to the system.and i also use protocol binding of these ports to the Wan 1
Phone system connect to a switchport
The sip trunk router connect to the Wan 1
My lan is connected to the Wan 2
Everything is working fine exept this intermittent issue : Each hour or so my sip trunk stop working. to make it start working i need to unplug my Wan 2 connection and wait for 1 minute.
in my system log i can't see any message regarding this problem
any ideas?
4 REPLIES 4
Rising star
Re: cisco RV042 Dual Wan issue for sip trunk
Good morning
Thanks for using our forum
Hi Dominic my name is Johnnatan and I am part of the Small business Support community. First of all, I apologize for the inconvenience you have with your device. In order to fix you r problem, are you using the latest firmware? The latest version is 4.2.1.02 you can download it in cisco.com
http://software.cisco.com/download/release.html?mdfid=282414010&softwareid=282465789
After the firmware upgrade you have to do a factory reset (Always make a backup of your data).I hope you find this answer useful and it fix your problem.
If this answer  was satisfactory  for you, please mark the question as Answered. Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
Beginner
hi johnnatan
i upgraded the firmware and made a factory reset and i still have the issue
Rising star
Hi dominic, ensure you  did the factory reset after the firmware upgrade, if you did that, you could chnge the “MTU” value, the default value is 1500. And to discard that it is a hardware problem, exchange your WAN connections, WAN1<-->WAN2, WAN2<-->WAN1.
I hope you find this answer useful, *Please mark the question as Answered or rate the answer so other will know when an answer has been found.
Greetings,
Beginner
hi
I did the factory reset after the update and i also changed the MTU value many time ( 500,1000,1200) and i still have the issue.What should i do next?
