Cisco RV042 port forwording case?
Plamen Angelov
Here is my situation. I have two real IP addresses on each of my WAN ports. I need to configure:
  1. port forwarding (80,443,3389) from Real_IP1 (configured on WAN1) to 192.168.116.10 (same ports)
  2. port forwarding (80,443,3389) from Real_IP2 (configured on WAN2) to 192.168.117.10 (same ports)
Router is confugured in System Management > Dual WAN as Load balancing.
192.168.116.0 is in vlan1 (port1)
192.168.117.0 is in vlan2 (port2)
Is it possible to make it working using Cisco RV042?
Thanks in advance!
mpyhala
Level 7
Level 7
Plamen,
Try to create an Access Rule like shown in the following example. On the second rule, select WAN 2 and use the other internal IP. I have never tested this but it looks like it might be a solution. (This is an older RV042)
Please let us know if this works or not.
- Marty
