cisco rv082 vpn remote local LAN
justinchen168
hi All,
i'm configuring the cisco router rv082 v1.
The VPN tunnel is not working when i using 0.0.0.0/0 as vpn remote local LAN, it work as normal when i using something like 192.168.1.0/24 as remote local LAN.
Any advice for this issue?
Justin
gersonchip
I have a similar problem, but i have already stablish my tunnel vpn but i cant make my users navigate using my asdl internet conected in a Sonicwall in my central office.
I configure the tunnel and create the routes but i have no navigation.
@justinchen168 wrote:
hi All,
Justin
