Hi Chan, thank you for using our forum, my name is Luis I am part of the Small business Support community. You created some access list to restrict the access from some ports, then you created port forwarding to specific port and you allowed the rule for this port, am I right? If I am right, make sure you save the changes when you change the rule, if the issue is the same please create a new rule allowing the access from this port to the destination address.
Bellow I will share to you a document to guide your configuration.
http://www.cisco.com/en/US/docs/routers/csbr/rv110w/administration/guide/rv110w_admin.pdf
You will see information in page 85, Configuring Services Management and Configuring Access Rules.
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
