01-28-2013 02:21 AM
Vi have a small business network including 2 QNAP 219 NAS servers. Several times we have noticed, the connection to the servers are lost. We have tried to restart the serveres without luck. But when we restart the router, all problems are gone and we can reconnect. It happens maybe one or twice a week. Annoying.
01-28-2013 05:34 AM
Hello Soeren,
What firmware version are you running?
Has it always done this?
Are you able to ping the NAS's when this happens?
Have you enabled logging to see if anything shows up in the logs?
First step is to make sure you are on the latest firmware. I know the very old firmwares were not stable at all back then but the latest firmware has made these devices very stable now.
Clayton Sill
02-04-2013 02:44 AM
Hi Clayton
· We are on 1.0.4.10 firmware release
· We could not ping the NAS in the situation
· The error have been there for a couple of months
· We have set up logging to see if anything goes into there
Latest log file
(The router was re-booted Sat Jan 4 11:35)
Notification log *************************************************************************************************
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Linux version 2.6.21.7-Cavium-Octeon (root@localhost.localdomain) (gcc version 4.1.2 (Cavium Networks Version: 1_6_0, build 34)) #1 Mon Jun 18 13:30:50 IST 2012
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Kernel command line: bootoctlinux 0x3000200 mtdparts=phys_mapped_flash:512k(bootloader)ro,5632k(kernel),8704k(rootfs),1024k(data),128k(bootload-env) console=ttyS0,115200
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] slram: not enough parameters.
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] number of CFI chips: 1
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 5 cmdlinepart partitions found on MTD device phys_mapped_flash
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Creating 5 MTD partitions on "phys_mapped_flash":
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 0x00000000-0x00080000 : "bootloader"
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 0x00080000-0x00600000 : "kernel"
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 0x00600000-0x00e80000 : "rootfs"
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 0x00e80000-0x00f80000 : "data"
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 0x00f80000-0x00fa0000 : "bootload-env"
Warning log *************************************************************************************************
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] CVMSEG size: 2 cache lines (256 bytes)
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] CPU revision is: 000d0601
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Determined physical RAM map:
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] memory: 0000000003800000 @ 0000000000700000 (usable)
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Built 1 zonelists. Total pages: 14116
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Primary instruction cache 32kB, virtually tagged, 4 way, 64 sets, linesize 128 bytes.
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Primary data cache 16kB, 64-way, 2 sets, linesize 128 bytes.
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] PID hash table entries: 256 (order: 8, 2048 bytes)
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Using 300.000 MHz high precision timer.
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes)
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes)
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Calibrating delay using timer specific routine.. 600.35 BogoMIPS (lpj=1200702)
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Mount-cache hash table entries: 256
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Checking for the multiply/shift bug... no.
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Checking for the daddi bug... no.
Sat Jan 1 01:01:22 2000(CET) [rv120w][Kernel][KERNEL] Checking for the daddiu bug... no.
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Enabling Octeon big bar support
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] PCI Status: PCI 32-bit
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] IP route cache hash table entries: 512 (order: 0, 4096 bytes)
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] TCP established hash table entries: 2048 (order: 3, 32768 bytes)
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] /proc/octeon_perf: Octeon performace counter interface loaded
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Total HugeTLB memory allocated, 0
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] RAMDISK driver initialized: 1 RAM disks of 500000K size 1024 blocksize
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] GACT probability NOT on
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Mirror/redirect action on
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] u32 classifier
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Performance counters on
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Actions configured
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] ip_conntrack version 2.4 (224 buckets, 1792 max) - 352 bytes per conntrack
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] ip_conntrack_rtsp v0.6.21 loading
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] ip_nat_rtsp v0.6.21 loading
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] ip_tables: (C) 2000-2006 Netfilter Core Team
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] netfilter PSD loaded - (c) astaro AG
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] ipt_time loading
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Bootbus flash: Setting flash for 16MB flash at 0x1ec00000
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Amd/Fujitsu Extended Query Table at 0x0040
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] phys_mapped_flash: CFI does not contain boot bank location. Assuming top.
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] cavium-ethernet: Cavium Networks Octeon SDK version 1.7.3, build 264
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Register the sysctl for hardware offload succeed
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Register the sysctl for flow cache succeed
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Register the sysctl for brcm Tag succeed
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Register the sysctl for vlan enabled succeed
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Pool 0 size 2048 No 1024
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Pool 1 size 128 No 1024
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Pool 3 size 128 No 640
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] global cache allocation start 0
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Ipforward global cache allocation sucessfull
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Registerd the sysctl for IMP port status
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Registerd the sysctl for 802.1x enabled port
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Registerd the sysctl for blocking non EAP packets status
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] Interface 0 has 2 ports (GMII)
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 996
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 999
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 1037
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] 1039
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] port ko 0
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] port ko 1
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] led module init...
Sat Jan 1 01:01:23 2000(CET) [rv120w][Kernel][KERNEL] umi: module license 'unspecified' taints kernel.
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] eth0: 100 Mbps Full duplex, port 0, queue 0
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] eth1: 100 Mbps Full duplex, port 1, queue 1
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] PF_key: Initialized Security Policy Database.
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] IPsec: Initialized Security Association Processing.
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] BUG: at kernel/softirq.c:138 local_bh_enable()
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] Call Trace:[
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
<4>Intializing the 8021P-DSCP Remark Module
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] Registerd the sysctl for _8021p task IMP portPCI: Enabling device 0000:00:03.0 (0000 -> 0002)
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] vap0: Broadcom BCM432c 802.11 Wireless Controller 5.60.120.9
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] ip_conntrack_pptp version 3.1 loaded
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] ip_nat_pptp version 3.0 loaded
Sat Jan 1 01:01:24 2000(CET) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sat Jan 1 01:01:25 2000(CET) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sat Jan 1 01:01:26 2000(CET) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sat Jan 1 01:01:29 2000(CET) [rv120w][System][PLATFORM] IPv6 not configured on the interface
Sat Jan 1 01:02:22 2000(CET) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Feb 4 11:37:51 2013(CET) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Mon Feb 4 11:54:11 2013(CET) [rv120w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Error log *************************************************************************************************
Sat Jan 1 01:01:27 2000(CET) [rv120w][Kernel][KERNEL] ip_conntrack_in: Frag of proto 17 (hook=0)
Sat Jan 1 01:01:50 2000(CET) [rv120w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Sat Jan 1 01:01:55 2000(CET) [rv120w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Mon Feb 4 11:37:51 2013(CET) [rv120w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Mon Feb 4 11:37:57 2013(CET) [rv120w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Mon Feb 4 11:38:14 2013(CET) [rv120w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Mon Feb 4 11:38:22 2013(CET) [rv120w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Mon Feb 4 11:38:57 2013(CET) [rv120w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Mon Feb 4 11:39:04 2013(CET) [rv120w][System][PLATFORM] [BONJOUR_ERROR]: DNSServiceProcessResult returned -65537 stopping listen to mdnsd
Mon Feb 4 11:39:06 2013(CET) [rv120w][System][PLATFORM] [BONJOUR_ERROR]: Signal Sent to bonjourClient Failed
Mon Feb 4 11:39:09 2013(CET) [rv120w][System][PLATFORM] [BONJOUR_ERROR]: Signal Sent to bonjourClient Failed
Mon Feb 4 11:39:10 2013(CET) [rv120w][System][EVTDSPTCH] umiIoctl (43, UMI_CMD_DB_UPDATE(4)) failed. table=FirewallRules row=99
Soren
