228
Highlighted
Beginner
Cisco RV130W port forwarding issue
Port forwarding is not working, need to forward ports 1730 & port 7625 to phone system IP. Added single port forwarding in admin section and pointed to correct ip but will not successfully forward the ports. Canyouseeme.org repeatedly errors when I test to see if port is open even though port forwarding says it is??
Any help would be appreciated, there are default ports available and I can successfully enable those but when I try to add the ports I need it will not succeed.
Critical issue as it has to do with several offices phone system communication.
1 REPLY 1
Highlighted
Enthusiast
You might want to open a case with Technical Services if urgent: 1 866.606-1866
