CISCO RV180 - Site to Site Basic Steps
Slava Zhilov
Beginner
Beginner
Good day!
May I ask about basic steps of creating a VPN tunnel between two CISCO RV180 routers. I'm trying to connect two remote local networks located in two different cities. Network A has a webserver which could be accessed only locally. I would like Network B users access to that server. Can the RV180 router located at Network B be a VPN clinet for RV180 located at Network A? Or they both should be gateways? If Network B has no external IP adress is that a problem? Do I need to create users for that connection or only IKE and VPN policy?
16 Replies 16
Slava,
Check the tunnel settings to see what encryption is used. Without encryption the tunnel will not connect, so it is always encrypted.
- Marty
Slava,
You are correct, you can increase the level of encryption and https is no longer necessary. For twice the security you can still use https if you wish.
- Marty
