11-20-2019 04:20 AM
We are using 3 RV320's for VPN between our locations.
Failover/Load balancing between the two Wan work perfect wihtout having any issues.
I wanted to make also a failover/Redundant connection with a USB Dongle.
Before everybody starts asking if it works or not, we are using D-Link DWM-157 which worked without any problem, neither on setup or failover. Tried all the possible situations ( Failover Hot / Cold / Primary), and always connected after a while.
The problem is.. How can I set it up for VPN, since we are using static IP's on all locations, and we are using Gateway to Gateway VPN. 3G/4G will never be static, and the thing is, that the two locations connect to a specific ip.
Moreover the remote group areas have a designated ip range, and when the wan's fail, it should open the 3/4g and connect again, thus opening ports and re-establish the vpn, without changing the remote Group's IP Address.
Any suggestions?
Solved! Go to Solution.
11-21-2019 01:47 AM
In the Local Group Setup, your IP address will be the public IP for WAN1.
Where in the Backup the remote IP is the Main IP of the Remote site.
The backup interface is the USB, so that is correct.
Regarding the the fact that the USB has no static IP, you can use FQDN.
This way you will have the same domain for both connection and overall for the VPN, but it will be resolved to different IPs.
You can consider that option too.
11-20-2019 08:40 AM
11-21-2019 12:56 AM
Thank you for your prompt reply.
I was thinking exaclty about that.
Setup of Remote Location >
But what about the other side, the main Location?
Since there is almost never a breakdown in the lines, should there be also another Setup / Backup.
Because the VPN Connection is set up like this:
Main Location Static IP> MMM.MMM.M.MMM ,Connect to ,Remote Location 1 Static IP > RRR.RRR.R.RRR
Remote Location 1 Static IP > RRR.RRR.R.RRR,Connect to ,Main Location Static IP> MMM.MMM.M.MMM
The question is, Since 3G/4G is not Static, is there going to be a problem?
Thank you
11-21-2019 01:47 AM
11-21-2019 01:53 AM
Ok, I think I got the point.
Thank you for your informations.
