Cisco RV340 and IPV4
Hello everyone,
I have a short question since I got puzzled by the documentation of the above-mentioned router. Does it support IPV4 protocol or it supports only IPV6.  From the specs, I cannot say it does.
Thank you very much for a prompt answer.
best regards,
Mihai
Seb Rupik
Hi there,
Although the datasheet only mentions IPv6, the configuration guide details plenty of IPv4 specific configuration:
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/Administration/EN/b_RV340x_AG.pdf
cheers,
Seb.
Sujoy Paria
Yes, it does support IPv4 Protocol. You may refer the quick start guide for the mentioned router…
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/Quick_start/EN/rv340_qsg_en.pdf
