Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
568
Hari Kumar Raja
Beginner
Cisco RV340 with Active directory use Authentication
Hello ,
i recently purchased Cisco RV340 and my current Firmware Version: 1.0.03.20 , i have configured ssl vpn with local users and able to connect with out any issues, i have an Active Directory and when i am trying to configure with my AD it was not authentication , i tried to configure as showing in cisco blogs but failed , can any one please help me out how can i fix this issue .
using Win2019 Standard server .
regards
Hari
9 REPLIES 9
balaji.bandi
VIP Guru
tell us what steps you followed :
1. you need to setup user accounts with Remote Authentication Service
2. Integrated with AD
3. you need to add your Device in AD as trusted device
follow below guide :
https://thesolving.com/server-room/configure-radius-server-windows-authenticate-cisco-vpn-users/
4. make a Groups so user will be part of VPN
check Logs both the side windows event logs and RV 340 what is the logs shows when the user dialed in ?
BB
Hi Balaji ,
i tried with this but no luck , i have configured radius on my win2019
server and when i am trying with AD users which was in group getting the
error . the authentication was thrown back .
attached log for cisco rv340 . can u please help me to fix this out .
regards
Hari
balaji.bandi
VIP Guru
So you are using Radius authentication, intern radius do AD lookup ? is this correct?
in this case you need to see related between radius and AD connection.
your Logs are missing ?
BB
yes ,
i have a AD setup for my users , most of the users will work remotely and
want to integrate with my AD , so we dont need to create local users and
they can use same domain logins to login .
attaching logs again .
regards
Hari
Your Logs still missing . - make sure attached correctly.
let me brief again.
1 user dial in to RV
2 RV use Radius to authenticate users
3. Radius installed in windows box - what radius ? is this windows NPAS ?
4. Do you have relation between Radius and AD in the same server for the users access ?
BB
Hi Balaji ,
any luck for my issue .
regards
Hari
let me brief again.
BB
Hari Kumar Raja
Beginner
I solved this my self after downgrading my DC from 2019 to 2016 , its worked with out any major changes in RV .
Thank you Balaji for your assistance .
regards
Hari
balaji.bandi
VIP Guru
thanks for feed back and glad all working as expected at end.
BB
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
