07-29-2020 12:00 AM
Hi all,
My RV345P has suddenly died.
It's powering on but I don't get any link lights on the switch ports.
The WAN interface port lights up as well as power.
I've plugged a console cable in and I see this:
It looks like it's having trouble loading the Cisco image?
The unit was not in the middle of an update - it just suddenly became unresponsive for an hour - unpingable - so I was forced to power cycle it.
Is it fried?
07-29-2020 12:16 AM
- Most probably (fried) as nothing was being done with the device in terms of firmware upgrade, you may try the firmware recovery procedure from the thread below :
https://community.cisco.com/t5/small-business-routers/rv325-won-t-boot/td-p/2766799
M.
08-02-2020 12:17 AM
No joy I'm afraid.
The DIAG light doesn't come on and no link on port1 - it's like the switch has not even been initialised.
I just get the message from the serial:
Active Image validation error
Copying Barebox from NAND Flash(bootopt=2) @offset = 0x80000
Reading ...
Done...Bytes read 0x80000
Image header CRC check failed
### ERROR ### Please RESET the board ###
Is there a way to boot off the USB with an image?
08-02-2020 12:29 AM
- I doubt it , have a factory defaults reset of the device, I doubt this will help , more about (standard) firmware upgrade methodologies can be found here :
M.
