Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
225
Highlighted
Beginner
Cisco RV345P How-To Import SSL Certs
Good day!  I have a issue where I am unable to locate where or how to import SSL certs in my new RV345P.
Had a RV325 and it allowed under certificates to import, but this is not an option that I have located on the new 345P model.
Has anyone done this or know of a way to import needed SSLs for our website to work properly?
TIA
1 ACCEPTED SOLUTION
Highlighted
In the Certificate area, click on Import Certificate. You will found there sub-menus as Local Certificate/CA Certificate/PKCS #12 Encoded file etc.
Import required certificate using the correct file and passport.
Deepak Kumar,
Don't forget to vote and accept the solution If this comment will make help you!
3 REPLIES 3
Highlighted
Beginner
So nobody has this router or knows if this can or cannot be done?  Ughhhhhh
SSL certificates importing or adding to the RV345P Router???
Highlighted
Deepak Kumar,
Highlighted
VIP Advocate
