08-05-2020 10:23 AM
Good day! I have a issue where I am unable to locate where or how to import SSL certs in my new RV345P.
Had a RV325 and it allowed under certificates to import, but this is not an option that I have located on the new 345P model.
Has anyone done this or know of a way to import needed SSLs for our website to work properly?
TIA
Solved! Go to Solution.
08-07-2020 03:04 AM
In the Certificate area, click on Import Certificate. You will found there sub-menus as Local Certificate/CA Certificate/PKCS #12 Encoded file etc.
Import required certificate using the correct file and passport.
08-06-2020 11:44 AM
So nobody has this router or knows if this can or cannot be done? Ughhhhhh
SSL certificates importing or adding to the RV345P Router???
08-07-2020 03:04 AM
08-07-2020 12:43 AM
(Look for 'Import Cerificate')
M.
