Cisco SA520 and OpenVPN - Firewall dropping connection
Smoker26104
Hello All,
I am attempting to set up OpenVPN server instead my network because the cisco QuickVPN bundled with the SA520 appliance does not seem to work well.
I have configured my OpenVPN server and client, but when I attempt to connect using the client the firewall drops my connection.I have set up an IPv4 firewall rule in the SA520 for the specific ports and IP addresses, but no matter what I do the SA520 drops the packets. I have tried using different port numbers and both TCP/UDP.I have another firewall rule set up for a web portal that works perfectly fine.
Dropped even log, Firewall Rule, Service Info
Thu Dec 4 13:32:13 2014(GMT -0500)WARNFIREWALL*Remote IP**Router IP*[firewall] LOG_PACKET[DROP] IN=WAN OUT=SELF SRC=*Remote IP* DST=*Router IP* PROTO=UDP SPT=52392 DPT=1194
Component: KERNEL
If anyone has any thoughts it would be appreciated.
0 Replies 0
