Dear Kevin,
Thank you for reaching the Small Business Support Community.
Could you please screenshot the VPN and IKE Policies so that we can check it out? Is there a Cisco support case currently opened? If so, please add the case number so I can follow the progress on it.
I'll be looking forward to your reply.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
