Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
333
Highlighted
Beginner
Cisco Small Business RV220W Wireless-N Network Security Firewall
I am new to this router and I was wondering if anybody could help me figure out how to block PING requests to the firewall through IPv4. I'm wanting to block ping requests from wireless VLAN. How do I go by getting this up and running? I have tried using the firewall access rules and blocking PING from inbound, Outbound, and VLAN. But for some reason I am still able to get replies from default gateway when I PING it. Any advice on how to counteract this?
Thank You,
Travis
5 REPLIES 5
Highlighted
Contributor
Hello, May I ask what is the
May I ask what is the purpose of this? I'm asking for two reasons:
1- I don't think it is possible. I tried it today and you are always able to ping the router's IP address from any VLAN no matter what configuration or restrictions I put in place on the router itself.
2- Not being able to ping the router won't actually hide it as the only thing you have to do to find out what the ip address of the router is, is to run an IP config and look at the default gateway.
If we know what is the end goal then we can give a better idea about how to accomplish it or just tell you if it is not possible,
Please let us know.
Highlighted
Enthusiast
Maybe this is fundamental
Maybe this is fundamental question concerning about firewall functionality of that router :-). If someone wanted to prohibit ping to gateway interface on device which supports firewall functionality, then it should work, right? (yes, I am not discussing about reasons why someone wants to achieve it).
How could anyone be sure about other customized firewall rules.. will they work or not?
Highlighted
Contributor
Hello Michal, To answer your
Hello Michal,
To answer your question, it is not possible to block pings to the default gateway on this router.
Customized firewall rules don't work either.
You can disable Device Management access for any VLAN you wish.
I hope this was helpful.
Highlighted
Contributor
And for the record, I've not
And for the record, I've not run into any brand's smb router that can be set up this way to deny lan pings.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Highlighted
Beginner
If you are trying to have the
If you are trying to have the router not respond to a ping from internally, I don't think that can be done.  From external, the settings are at Firewall->Attack Prevention.
