05-30-2013 07:15 AM
Hello i want to use a Speedstick LTE (Huwaei E398) whit a Cisco SRP 526W as Backup. (Provider is T-Mobile Germanny)
The Cisco dosn´t recognize the Stick on USB Port. I have upgrade the Cisco to the latest Firmware but the Stick doesn´t work.
what can i do?
05-30-2013 07:43 AM
We did test the E398u-15 with SRP500 release 1.2.5. Is this the same as your card?
Are you seeing Not Detected, or Not Connected?
Andy
05-30-2013 07:55 AM
Hi Andy, my Card is a E398 without u-15 supplement. (Is a LTE Card)
I mean i see not detected.. I will check this again and report later..
05-30-2013 08:02 AM
When you check, make sure that the multi-WAN config page is configured to allow failover.
Usually Huawei modems are pretty consistent, but sometimes service providers use different firmware on the modem that causes the SRP not to recognise them.
Andy
05-30-2013 01:47 PM
05-30-2013 02:16 PM
Ok - not sure what we will ultimately be able to do now, but if you could do the following, it will allow us to move things along:
Andy
05-31-2013 02:58 AM
Hi, the Support Team could not help because the device is to old .:(
here is the LOG(do not look Date) :
Dec 31 17:01:46 SRP526W daemon.alert 3G[356]: init 3G card failed at init phase, will reset USB host... |
Dec 31 17:01:46 SRP526W daemon.notice 3G[356]: Init USB 3G card HUAWEI_E352_SERIES failed |
Dec 31 17:01:46 SRP526W daemon.alert 3G[356]: USB3G: ARRANGE FOR RESET USB... |
Dec 31 17:01:49 SRP526W daemon.alert 3G[356]: USB3G: POWER OFF USB |
Dec 31 17:01:49 SRP526W daemon.notice 3G[356]: USB3G: remove card 0x12d1/0x1506 bus#=1 dev#=5 |
Dec 31 17:01:50 SRP526W daemon.info 3G[356]: inform rc remove 3G card |
Dec 31 17:02:00 SRP526W daemon.alert 3G[356]: USB3G: POWER ON USB |
Dec 31 17:02:19 SRP526W daemon.notice 3G[356]: USB3G: add card 0x12d1/0x1506 bus#=1 dev#=7 intf#=7 port#=974 |
Dec 31 17:02:19 SRP526W daemon.info 3G[356]: init 3G card phase init |
Dec 31 17:02:40 SRP526W daemon.alert 3G[356]: init 3G card failed at init phase, will reset USB host... |
Dec 31 17:02:40 SRP526W daemon.notice 3G[356]: Init USB 3G card HUAWEI_E352_SERIES failed |
Dec 31 17:02:40 SRP526W daemon.alert 3G[356]: USB3G: ARRANGE FOR RESET USB... |
Dec 31 17:02:43 SRP526W daemon.alert 3G[356]: USB3G: POWER OFF USB |
Dec 31 17:02:43 SRP526W daemon.notice 3G[356]: USB3G: remove card 0x12d1/0x1506 bus#=1 dev#=7 |
Dec 31 17:02:44 SRP526W daemon.info 3G[356]: inform rc remove 3G card |
Dec 31 17:02:53 SRP526W daemon.alert 3G[356]: USB3G: POWER ON USB |
Dec 31 17:03:13 SRP526W daemon.notice 3G[356]: USB3G: add card 0x12d1/0x1506 bus#=1 dev#=9 intf#=7 port#=974 |
Dec 31 17:03:13 SRP526W daemon.info 3G[356]: init 3G card phase init |
05-31-2013 03:50 AM
Ok I learn that the Huwaei E398 works only whit the SRP 526W-U. Not whit the SRP 526W.
Bye
