Hi all,
I have a Cisco VPN RV042. I have issues with the login for the router. When I type into the address bar, it gives me a browser error. I have to restart the router each time for the login screen to work. Any ideas?
Second,
This RV042 connects to a switch that then connects to all the other devices. I set up my RV042 network so all the devices will be a custom network 192.168.12.1 so all the devices will be 192.168.12.###. But the issue is sometimes the device IPs connect to 192.168.1.1 and have an IP address of like 192.168.1.200. This results in the device not having internet because it's pinging to the RV042's 192.168.14.1
If I turn everything off, and then power back the router and switches, then the devices will reconnect to 192.168.12.1 but this is causing alot of problems.
Is there something wrong?
