Cisco WRV210 problem port forwarding POLAND
t.cichowicz
Witam
Urzadzenie nie chce przyjac ustawien przekierowania portow, router zglasza sie adresem MAC 00:00:00:00:00:05.
Device dont change port forwarding settings, router have mac address 00:00:00:00:00:05. Device not working properly.
Tom Watts
Jesli nie mozesz zastosowac ustawien z WEB UI sprobuj innej  przegladarki internetowej jak Firefox, Chrome, itd. Mozesz rowniez  sprobowac starszej wersji IE7 albo IE8, lub IE9 z opcja zgodnosci przegladnia.
Jesli to nie dziala zaktualizuj router do nowej wersji software 2.0.1.5 i przywroc ustawienia  fabryczne wciskajac przycisk reset przez 35-40 sekund.
If settings do not apply from the WEB UI, try a different  browser such as Firefox, Chrome, etc. You may also try older IE 7 or 8  or IE 9 in a compatibility view.
If it still does not  apply setting for the port forwarding, give the router a firmware  upgrade to the 2.0.1.5 and factory reset the unit holding the reset  button for 35-40 seconds.
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Thanks Thomas. I use Firefox, Opera, Chrome and IE8 but some part of web gui dont work(example
http://192.168.103.1/SetupPPPoE.asp a have empty white screen)
. I have firmware 2.0.1.5 and this firmware was installed 3 times, when device not working properly. This is strange device, I must every mont reinstall firmware in device, this behavior is not normal.
Most of the time when the web UI does not display correctly, it is an issue with the computer accessing the device. Very, very seldom it is the router.
Try a different computer and see if it yields a result. The router UI use Java and the way computers handle Java are different for whatever reason. The WRV210 is a bit of an older router also, new operating system / security patches sometimes affect how the html loads within the UI for the older products.
-Tom
