12-05-2012 06:15 AM
I am trying to allow RDP access to my server through my RV042.
I added an access rule:
Action: Allow
Service: RDP [3389]
Source Interface: WAN1
Source: Any
Destination: 192.168.2.10
Time: Always
192.168.2.10 being the internal IP address of my server.
But, when I try to RDP in, I cannot connect.
Any suggestions as to what I am doing wrong?
Many thanks,
Chris
12-05-2012 08:29 AM
Hello Mr. Buie,
Please check that on the firewall options you have the next configuration
Block Wan Request: Disable.
Remote Management: Enable.
Diego Rodriguez
Cisco network engineer
Thank you
*If this answer was satisfactory for you, please mark the question as Answered.*
12-05-2012 08:38 AM
Block WAN Request was enabled ... I changed that to disable.
Remote Management was already enabled.
Unfortunately, still unable to connect.
12-05-2012 09:03 AM
Hi Christopher, to add to Juan's post, did you create a port-forwarding rule?
If you want redirect the RDP service to a specific ip, you have to create this rule.
In order to do this, follow these instruction:
1. Go Firewall>Access rule
2. Click on Service Management> and configure each space like this.
Service name : RDP
Protocol:TCP
Port Range: 3389 to: 3389
Add to list > Save Settings > Exit
3. Configure each space like this
Action:Allow
Service: RDP [TCP/ 3389-3389]
Source IP:any
Destination IP: 192.168.2.10
4. Save settings
I hope you find this answer useful, if it was satisfactory for you, please mark the question as Answered.
Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
