Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
5310
cjbuie358
Beginner
Configuring RDP Access with an RV042
I am trying to allow RDP access to my server through my RV042.
I added an access rule:
Action: Allow
Service: RDP [3389]
Source Interface: WAN1
Source: Any
Destination: 192.168.2.10
Time: Always
192.168.2.10 being the internal IP address of my server.
But, when I try to RDP in, I cannot connect.
Any suggestions as to what I am doing wrong?
Many thanks,
Chris
3 REPLIES 3
jurodri3
Beginner
Hello Mr. Buie,
Please check that on the firewall options you have the next configuration
Block Wan Request: Disable.
Remote Management: Enable.
Diego Rodriguez
Cisco network engineer
Thank you
*If this answer was satisfactory for you, please mark the question as Answered.*
Block WAN Request was enabled ... I changed that to disable.
Remote Management was already enabled.
Unfortunately, still unable to connect.
Bloa
Hi Christopher, to add to Juan's post, did you create a port-forwarding rule?
If you want redirect the RDP service to a specific ip, you have to create this rule.
In order to do this, follow these instruction:
1. Go Firewall>Access rule
2. Click on Service Management> and configure each space like this.
Service name : RDP
Protocol:TCP
Port Range: 3389   to:  3389
Add to list > Save Settings > Exit
3. Configure each space like this
Action:Allow
Service: RDP [TCP/ 3389-3389]
Source IP:any
Destination IP: 192.168.2.10
4. Save settings
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered.
Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
