09-05-2012 10:27 PM
I have
Model: | SRP527W, ADSL2+ AnnexA, 802.11n ETSI, 2FXS/1FXO |
Product ID: | SRP527W-U-E-K9 |
I need to block Yahoo and MSN messenger using either ACL or Advanced Firewall.
Simon Yee
Solved! Go to Solution.
09-18-2012 12:00 PM
you can use ACL in router to block MSN and Yahoo, also you can block another websites as facebook.
Messenger:
access-list 102 deny tcp any any eq 1863 log
access-list 102 permit ip any any.
Facebook:
access-list 1 deny 69.63.184.0 0.0.0.255
access-list 1 permit any
yahoo:
access-list 10 deny 98.139.183.0 0.0.0.255
access-list 10 deny 98.138.253.0 0.0.0.255
access-list 10 permit any any
If this answer was satisfactory for you, please mark the question as Answered.
Thank you
Greetings, Johnnatan Rodriguez Miranda
09-06-2012 08:40 AM
Hi Simon,
It likely is not possible to block the messenger services. The router blocks by port to static IP address. Meaning if you block port 443 or 80, you will block almost all internet functions.
-Tom
Please rate helpful posts
09-06-2012 07:55 PM
Hi Thomas,
I just only block the port 5050 only.
But looks like it cannot work. hurmmpp
Best Regards,
Mr. Simon Yee
Document Control
Budi Feed Sdn. Bhd.(827186-P)
Lot 11940, Jalan Perajurit 1,
Off Jalan Perajurit,
Kampung Tengah,
Telok Gong,
42000 Port Klang,
Selangor Darul Ehsan.
Tel :-- 603-3134 1081
Notice of Confidentiality:
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, re-transmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender immediately by return electronic transmission and then immediately delete this transmission, including all attachments, without copying, distributing or disclosing same.
09-06-2012 08:34 PM
Simon, here are the ports MSN messenger uses alone;
The following table lists the network ports that are required for various features of Windows Live Messenger 8.1 on a Windows Vista-based computer.
Collapse this tableExpand this table
Feature | Port that is used |
Sign in to the Messenger service | TCP 80, 443, 1863 |
Network Detection | TCP 7001 UDP 9, 7001 |
Audio | TCP 80, 443, 1863 TCP/UDP 30000 - 65535 |
Audio (Legacy) * | UDP 5004 – 65535 |
Webcam and Video Conversations | TCP 80 TCP/UDP 5000 - 65535 |
File Transfer | TCP 443, 1863 TCP/UDP 1025 - 65535 |
File Transfer (Legacy) * | TCP 6891 - 6900 |
Sharing Folders | TCP 1863 TCP/UDP 1025 – 65535 |
Whiteboard and Application Sharing | TCP 1503 |
Remote Assistance | TCP 3389 TCP/UDP 49152 – 65535 |
Windows Live Call | TCP 443, 5061 UDP 5004 - 65525 |
Games | TCP 80, 443, 1863 TCP/UDP 1025 - 65535 |
The SRP can block by IP address or by service. If you know every IP address the MSN services use, you may try...
But if you block these ports, you will block a lot more than MSN messenger. The router cannot support this.
-Tom
09-17-2012 01:52 PM
You can use ACL in router to block MSN and Yahoo, also you can block another websites as facebook. Messenger: access-list 102 deny tcp any any eq 1863 log access-list 102 permit ip any any. Where it is assumed that 1863 is the port used and the lock would block all msn. Facebook: access-list 1 deny 69.63.184.0 0.0.0.255 access-list 1 permit any yahoo: access-list 10 deny 98.139.183.0 0.0.0.255 access-list 10 deny 98.138.253.0 0.0.0.255 access-list 10 permit any any
Thank you
09-17-2012 06:21 PM
Hi Juan Diego Rodriguez Estrada
How do I key in this & how do I key in this?
Best Regards,
Mr. Simon Yee
Document Control
Kampung Tengah,
Telok Gong,
42000 Port Klang,
09-18-2012 12:00 PM
Messenger:
Facebook:
yahoo:
Thank you
