Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
623
willloving
Beginner
Connecting two SRP527W's
So I'm trying to connect two SRP527W's.  I have 2 different sites, 2 SRP527W's, 2 ADSL connections.  I deally I would like to connect the 2 sites using an ethernet cable from the back of each SRP.  The reason why I wanbt to do this is that we are located in an area with poor ADSL infrastructure and bandwidth is an issue.  I don't want to share the ADSL connection at each site I just want one site to be able to access the network of the other as they need to access the server.
Below is my current setup:
Site 1.
SRP527W with ADSL connection
IP: 192.168.15.1
DHCP Server
D-Link unmanaged 24 port switch
15 Computers connected
Server
Site 2.
IP: 192.168.1.1
DHCP Server
7 computers connected
Cisco 10 port managed switch
Is it possible to configure port from the SRP @ Site 2 (not from the switch)  to connect with the server at site 2 without the DHCP interferring and trying to change IP addresses?
I'm quite new to networking so any suggestions would be appreciated.
2 REPLIES 2
jonatrod
Rising star
Hi Will, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. If I understand well you could set the IP address statically in order to avoid the IP address changes due the DHCP.
If not, please could explain us a little more about your issue?
I hope you find this answer useful
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
Andrew Hickman
Hi Will,
By default, the SRP issues DHCP address from 192.168.15.100 upwards.  Choose anything from .2 to .99 to statically address your server.
Not sure about your requirement for connecting the two routers.  Are you suggesting that both devices are close enough (<100m) to connect them via Ethernet on the LAN side of the SRPs?  If so, sure you can do this a number of ways.  Here is just one:
Make sure that you are using different IP subnets on the two SRPs (ie change the default on at least one of them)
Create a new VLAN (5 for example) on both routers and assign this as the only VLAN for the ports you wish to connect together.
Statically assign an IP address from the same subnet to this VLAN on both routers: 192.168.5.1 on one and 192.168.5.2 on the other.
Create static routes on each SRP pointing to the remote LANs via the other SRP's 192.168.5.x address.
So you might have:
192.168.15.x <-> SRP A <-192.168.5.1 ..Ethernet cable.. 192.168.5.2 -> SRP B <-> 192.168.20.x
At SRP A create route to 192.168.20.0 255.255.255.0 via 192.168.5.2 and at SRP B create a static route to 192.168.15.0 255.255.255.0 via 192.168.5.1.
Hope that makes sense.
Andy
