Connectivity Issue with RV042G and SG300-10 Switch (Layer 3)
Romeo Sulzer
Due to its dual WAN feature, we replaced our Linksys EA4500 Router with a Cisco RV042G. Attached to the RV042G router is a Cisco SG300-10 Switch in Layer 3 Mode. The LAN is structured as follows:
VLAN 100 (Internal Clients)
  • 10.1.1.0 / 24
  • Default Gateway: 10.1.1.1 (RV042G)
  • SG300 Interface:  10.1.1.254
  • DHCP Relay to 10.1.0.200
  • DNS for Clients: 10.1.0.200
VLAN200 (Guest Clients)
  • 10.1.2.0 / 24
  • Default Gateway: 10.1.2.254 (SG300 IPV4 Interface)
VLAN 300 (Servers)
  • 10.1.0.0/ 24
  • Default Gateway: 10.1.0.254 (SG300 IPV4 Interface)
  • DNS and DHCP Server: 10.1.0.200
On the RV042G I’ve added the following static routes:
  • 10.1.0.0 / 24
  • Next hop: 10.1.1.254
  • Metric: 1
  • 10.1.2.0 / 24
  • Metric: 1
On the Linksys EA4500 this configuration worked without any issues. However, with the RV042G I cannot access the internet when I connect to VLAN  on the SG300. If I connect directly to one of the LAN ports of the RV042, I can access the internet without any issues.  It looks like a routing issue, since a tracert revealed a time out after reaching the SG300’s IPV4 Interface (10.1.0.254 and 10.1.2.254). I’ve verified that there is a static route to 10.1.1.0 / 24 on the SG300.
Any obvious things I’ve missed?
Thank you for your appreciated help!
Romeo Sulzer
I was able to solve the issue described above by adding the VLAN subnets under Setup -> Network -> IPv4 -> Multiple Subnets.
I've noticed that in the RV042G you can only add up to 5 additional subnets, our network has more than that.  Is there any work around?  Could this limitation be removed/increased in a future firmware update?
Hello Romeo,
You are correct in the work around you came up with.
The RV042 does not NAT for non-native VLANs (as in VLANs that it does not known about) so unless you create those VLANs on the RV042, those subnets from your layer 3 switch won't be able to get out to the internet.
From what I've seen there are no plans to increase this number, since the RV042 can only support a few VLANs to begin with.
You can however go with an RV220W or ISA as they do have the ability to specify the non-native VLANs to be NATed.
Thank you for choosing Cisco,
Christopher Ebert
Senior Network Support Engineer - Cisco Small Business Support Center
Dear Christopher
Thank you very much for your reply.  Actually what I found out is that starting from firmware version 4.x I need to create a firewall access rule for each additional subnet's IP range.  With the access rules in place, the internet connectivity works now without defining the multiple subnets.
I suppose the multiple subnets I only need if I want to forward ports to one of the non native subnets?
Kind regards,
Romeo
