Control Panel for 891F-K9
gdhia
Beginner
Beginner
I am willing to buy a 891F-K9 router and i wanted to know, if it will be possible to install a Control Panel usable through internet browser to configure the router and its functionnalities.
I have seen in the following table, that there is a mention of this model and its integration with CP express, but i'm not sure of my understanding.
Kind regards.
ktonev
Hi gdhia,
The ISR series are not considered a Small Business router (such as the RV series). I'd suggest to post your question to the main Routing section so your post can get the appropriate visibility and be answered sooner. If your issue is urgent you can also call our support centre for assistance.
Thank you!
Recognize Your Peers
