06-07-2014 02:47 AM
Hello everybody,
I've set up multiples VLAN on my RV325, firmware 1.1.1.06.
All of them are managed with DHCP server, sometimes with reserved IP for some MAC address.
On one of theses VLANs I would like to set up a 255.255.0.0 subnet mask. Is there a way to define it on DHCP configuration?
the DHCP subnet is provided in a select box which contains only some values like 255.255.255.x?
Kind regards
David
08-04-2016 01:09 PM
Has anybody found a workaround for the subnet mask limitation to /24 only? I am really in need to extend to a /16 network - Even Basic TP-link routers are able to do that, but not a Cisco RV325!
08-09-2016 12:37 AM
Hello Jean-Michel,
I am really sorry for the inconvenience you are experiencing.
Please be advised that indeed there is a device limitation to only /24 subnets or higher and the only workaround would be to place another DHCP server (and disable the RV325 one) in your network that can give /16 IP addresses.
Kind regards,
Milan Milanov
08-14-2016 11:44 AM
Dear Milan -
Thank you for replying. It is not so much the DHCP limitation by itself (I can live, so far, with that), but the need to have a higher number of hard coded infrastructure addresses, and clustered in a way that would make sense eg 168.1.30.xxx for same type of equipment, 20.xxx for another, 1.xxx for DHCP, 2.xxx for VPNs for example , but I still need the a type C (/16) subnet for that. Anyway to achieve that?
Let me know.
Best regards
02-17-2020 11:37 AM
This is embarrassing!
a Cisco router with these limitations (not Class B). I'm really angry at Cisco. The company gives no explanation or solution, does not apologize, is silent and collects their money.
