01-27-2021 09:57 AM
I want to disable the DHCP of the router, because I have a 3rd party DHCP server
How can I do that ?
Thank you.
01-27-2021 10:03 AM
- Check the DHCP settings ,presumably if not scopes are configured , it will not respond to dhcp requests (too).
M.
01-27-2021 10:25 AM
Im accessing it via console cable, i cant access the gui
01-27-2021 11:03 AM
01-27-2021 03:43 PM - edited 01-27-2021 03:44 PM
Follow the below guide and select disable DHCP button.
save and commit the config.
and configured DHCP helper-address / relay to get IP from 3rd party DHCP Server
01-28-2021 03:43 PM
I can't access the GUI
01-28-2021 04:24 PM
RV Model have less access to cli,
1. is he IP pingable?
2. check with another browser?
3. reboot the device. and try.
if all the options failed above, the only option is to reset to factory default to get GUI access only if you have a backup of the device config?
