Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
357
shehanfernando
Beginner
Enable nbar2 on zone base firewall - cisco 881
IOS version :- c880data-universalk9-mz.154-3.M4.bin
I'm looking to enable NBAR2 on cisco 881 router according to this doc . I couldn't find command called "nbar-classify" inside the following parameter-map command. Appreciate any feed back to fix this
(config)#parameter-map type inspect global
1 ACCEPTED SOLUTION
Philip D'Ath
Advisor
You missed this important bit.
In Cisco IOS Release 15.5(1)T and later releases, zone-based firewalls supports Network-Based Application Recognition 2 (NBAR2).
1 REPLY 1
Philip D'Ath
Advisor
