Get the latest Cisco news in this December issue of the Cisco Small Business Monthly Newsletter
6942
Beginner
Error using PPTP passthrough in RV180W
Ross,
I have been working with Cisco on 2 issues pertaining to this router.  1 was the port forwarding issue which was resolved in 1.0.2.3.
A new version 1.0.2.6 was officially released a few weeks ago.  I have it loaded and operational.  Even though it does not resolve the PPTP issue.
I received word that Tech support was able to reproduce the issue and engineering was working on a fix last week.
Yesterday I received firmware revision 1.0.2.8 with notes indicating that it has resolved the PPTP issue.  I will try it out tonight.
Highlighted
Beginner
Re: Error using PPTP passthrough in RV180W
Great! I'd be really interested to hear how you got on.  I too was sent 1.0.2.8, unfortunately it was sent over the easter bank holiday weekend and the 3-day link had expired by the time I received it this morning
Beginner
Ross,
It didn't work for me.  I am goping to take some more captures today.
Brandon
Beginner
Brandon,
1.0.2.8 + factory reset didn't work for me either, the same problem still persists using the Windows 7 PPTP client.  I haven't tested XP.
Beginner
Having given up using this router some time ago, I thought I'd dust off the RV180W, re-flash with the latest firmware 1.0.3.10 (which apparently has a PPTP/PPPoE fix) and try it again.
I reset to factory settings and configured the basic minimum settings for a NAT router on my PPPoE fibre internet connection. Before I tested the VPN, I tried to do some basic web-browsing to prove that I had internet access. This failed as I could only load half a webpage before the browser would give up. Not a good start but pretty much what I've come to expect from this hardware. Power-cycling seemed to solve the issue.
I tested the VPN again and it is still broken in the same way it always was, ending in an Error 628.  So a year after I bought this router, I still can't use it due to firmware bugs. Ah well, back to my trusty DLink/DD-WRT.
Did anyone else with this issue find that 1.0.3.10 worked for them?
Beginner
I'm having the same problem still after upgrading to 1.0.3.10 (from 1.0.2.6).
Is there anything that can be done? A beta firmware to try perhaps?
thanks
Beginner
Update please? Can a support case be opened for this issue?
Beginner
It's a geting a bit ridiculous now. If there won't be an update released any time soon, then I'll just turf this router and gert another one.
Keeping people in limbo like this is not right.
Beginner
If you want to create a support case, you'll probably have to initiate it by phoning the small business router support team. They opened a case for me but couldn't solve the issue before I lost access to the problem VPN server.
TBH, I just gave up and got another router in the end.  I haven't looked at the market for a while but I got a DD-WRT based router and it had all the features I needed. (DD-WRT is third party party firmware that can be flashed into some off-the-shelf routers).
Contributor
This is very interesting, and simply crazy that it's not been addressed after years.
Here's an idea.  Try putting the rv180 in the dmz of another router so you're not having to use pppoe for the IP.  Then try it and see what happens.  If so, then at least we know it's only a bug on the pppoe side, and if someone has a combination dsl modem-router, they can leave it in router mode and put the rv180 in the dsl router's dmz as a workaround.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Beginner
Good idea.  Unfortunately I don't have access to the problem VPN server any more or I would give this a go.
Tech support did initially test the RV180W against the problem VPN server without using PPPoE and it apparently worked OK.  Because of this I had difficulty persuading them there was a problem as they were unable to test with PPPoE at the time.  I was told eventually that they had replicated the problem but since their fix didn't work for me it must have been a different problem.
Contributor
So you still have the rv180?  Is it being used at all?
Beginner
Yep, still have the RV180.  The case support case dragged on, I lost the box, the unit got scratched and decided I probably couldn't send it back even if I could be bothered.
It now sits at the back of my hall cupboard and takes up just the right amount of space to prevent cans of shoe polish from sliding too far back where I cant see them.  This is of course the most useful purpose its ever had.  I use a D-Link DIR 615 with DD-WRT for my house router, no complaints.
Maybe I'll ebay the RV180 at some point, clearly some people have found it to be useful. Or perhaps attack it with a lump hammer which would in many ways be more rewarding!
Contributor
lol, I know the hammer feeling.  But if it works other than your problem, it may solve an issue that I have for needing a replacement gateway at my main site.  I'm only going to be using basic stuff like vpn and reserved dhcp, so it should do fine for my needs if you want to sell it.  I have a UPS account so I can even handle the shipping costs.  PM if you're interested.
Rising star
Brett,
Please do open a support case for this issue. The more cases that are logged, the higher the priority this issue will be.
www.cisco.com/go/sbsc
- Marty
