Firepower 1010
techpros
Have a Firepower 1010 that keeps enabling SIP Inspection anytime there is a change made via the webui or rebooted.  How do I make the change permanent in FTD?
balaji.bandi
How are you disabling ? sip inspection.
is this FTD managed by FMC, - or FTD.
Either case you need to make changes in Flexconnect is the best approach. we had the same issue i followed and make a document as we deployed. some information pulled from different sites to make it work.
https://www.balajibandi.com/?p=1284
BB
FTD, I believe.  Configuring by SSH.
balaji.bandi
FTD either manage by FDM or FMC, so make sure you config flex config for long saved.
BB
