06-06-2012 08:03 AM
I am trying to download firmware for an RV180W Wireless-N Multifunction VPN Firewall Router. I found updates for a 110 in BIN format (router only updates from IMG). Does anyone know of another link for this? Currently running stock firmware on that router and need the update. Thanks
06-06-2012 09:14 AM
If there is none list then thats it until one is released. you could try asking Cisco SBSC
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
you'd need to rasie a ticket for them to give you a possible "Beta" firmware.
Is this "the Update" you are speaking about? What Version is your stock firmware?
Regards Simon
http://www.linksysinfo.org
06-08-2012 09:26 AM
Because they had the documentation out since May, I was hoping to avoid that ... but I will hold on to that link for future reference. Thanks, Simon.
To other readers, Cisco posted the firmware sometime on 6/6 so it is there as of this writing.
