Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1121
axialinfo
Beginner
Firmware update for RV120w 1.0.5.6
I have some trouble with the last firmware. I can't get the web Access on the WAN interface since I upgrade to the last firmware.
Can I come back to the Version 1.0.4.10.
Thank you,
John
1 ACCEPTED SOLUTION
jeffrrod
Enthusiast
Dear John,
Thank you for reaching the Small Business Support Community.
Just to make sure you configure the Web Access and Management correctly, I suggest you to check on page 119, chapter 7, of the admin guide;
http://www.cisco.com/en/US/docs/routers/csbr/rv120w/administration/guide/rv120w_admin.pdf
If you still wish to go back to the firmware version 1.0.4.10, the release notes does not say that it will make factory default of the configuration, but I would advise to make factory default after the downgrade and to reconfigure manually the device. The new firmware versions contain big fix and enhancements. Once you downgrade you just lose the fixes. You can see the Release for more information:
http://www.cisco.com/en/US/products/ps9923/prod_release_notes_list.html
http://software.cisco.com/download/release.html?mdfid=282981372&flowid=796&softwareid=282487380&release=1.0.5.6&relind=AVAILABLE&rellifecycle=&reltype=latest
Please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
3 REPLIES 3
jeffrrod
Enthusiast
Dear John,
Kind regards,
Thank you Jeffrey for your help,
I just forgot to tell you that I always went to the web access before I upgraded the RV120w  firmware from 1.0.4.10 to the 1.0.5.6.
But I looked again the configuration and all is good.
The rv120w is behind an ISP which is configured as a routeur. I made port forwarding on port 500, 4500 (VPN which is ON ) and 60443 for the web access on the RV120w. But I can't get the web access.
If I can, I would not like to come back to the 1.0.4.10 firmware.
So if someone have an idea, I'm listenning you...
Thank you Jeffrey,
You were right. With the firmware 1.0.4.10 we don't have to enable HTTPS Web Access on LAN Interface to get the access on the Wan interface.
But with the firmware 1.0.5.6 we must enable HTTPS Web Access on LAN Interface to get  the web access on the WAN interface.
Thank you Jeffrey.
