Force RV340 under load balance to always use a WAN for a given IP
HikariWS
Hello. I'm using Cisco RV340 with 2 independent ISPs under load balancing.
I wanna monitor each of these ISP in case they go down. By tracerouting I've chosen 1 IP inside each of their networks to monitor.
But, during tests, I figured that their IPs are publicly available for pinging. That means that when a ISP goes down, I still can ping its IP by the other ISP. Therefore I'm unable to (easily) monitor if and when they go down.
My next guess would then some way to force each of these 2 IPs to only be routed to their equivalent WAN port. If its ISP goes down, RV340 won't try to route to to the other WAN port and ping will fail.
What would be the best and simplest way to achieve that?
0 Replies 0
