Hi guys, I have a problem with my CISCO 891 Router.
I configured Internet failover with IPSLA, track and route map, these work fine and I want to configure port forwarding but I don't know how, I need the port forwarding working on the primary ISP(giga0) and change it when the primary ISP down and secundary (fast8) up.
I wrote this command:
ip nat inside source static tcp 192.168.1.202 3074 interface giga1 3074
and
ip nat inside source static tcp 192.168.1.202 3074 interface fa8 3074
When I write the last command, this delete the first (I think, because has the same port and the same IP inside or the interfaces are WAN).
How I can homologate these commands? or How can I do to configure port forwarding to work with two WAN interfaces (Internet failover)?
Please Help me!
Regards.
P.S. Sorry for my bad grammar XD
You must use route-map also in ip nat configuration.
Try to see this link: NAT failover with DUAL ISP on a router with Policy Based Routing
http://binaryglobal.com/blog/?p=129
Regards.
