02-15-2015 01:58 AM
Hi, all,
I have 3x RV320 with latest firmware all set up to use gateway to gateway VPN in a spoke and hub configuration.
On all RV320, I can see the status of VPN tunnels as connected. However, I am not able to ping from gateway to gateway nor from the computer connected to each RV320. Firewall has been turned off on all RV320.
Any help will be appreciated.
regards
J
Solved! Go to Solution.
02-24-2015 05:56 PM
Try the ping from the diagnostic page of each rv320. Can the rv's ping each other? If so, your tunnel is up, but something is wrong in the subnet configs.
02-24-2015 05:56 PM
03-26-2015 02:45 AM
Did you get this resolved? I am having the same issue and wondering what the fix action was. Thanks!
Tim
03-27-2015 09:28 AM
What is your tunnel configuration? There's a bunch of things that could be wrong.
03-27-2015 09:36 AM
My thread is here: https://supportforums.cisco.com/discussion/12456006/rv320-rv320-gw-gw-vpn
03-27-2015 11:09 AM
I answered in your thread. :)
06-25-2015 08:47 PM
Hi Samir
thank you for this
it is exactly the incorrect subnet setting
j
