Help with Cisco 857 & VLANs
dleylandjfdi
Hi all,
bit of an issue, does anyone know if the 857 router supports VLANs with any image?
I don't seem to be able to add VLANs.
I was sold the box on the grounds it did support VLANs, but it only allows one in the database.
If it doesn't support VLANs, what is the smallest Cisco router that does?
HELP Please
Dave
Correct, only 1 VLAn supported on this device. You may want to look into the 1800 ISR series.
Marcos
