04-01-2020 12:14 AM - edited 04-01-2020 12:33 AM
Hello guys how are you today?
My name is Daniel. I need on help on this special request.
Im really senior on cisco config and commands and thats why I post it this message, to see if someone can help me.
The case is: my router 2951 make a lot noise. I check is one fun.... when i see the command sh env the system show me that
DESMS-ROUTER#sh env
SYSTEM POWER SUPPLY STATUS
Internal Power Supply Type: AC
Internal Power Supply 12V Output Status: Normal
External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
Fan 1 OK, Low speed setting
Fan 2 OK, Low speed setting
Fan 3 OK, Low speed setting
Fan 4 OK, Low speed setting
SYSTEM TEMPERATURE STATUS
Intake Left temperature: 19 Celsius, Normal
Intake Right temperature: 20 Celsius, Normal
Exhaust Left temperature: 32 Celsius, Normal
Exhaust Right temperature: 27 Celsius, Normal
CPU temperature: 50 Celsius, Normal
Power Supply Unit temperature: 30 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
SYSTEM POWER
Motherboard Components Power consumption = 67.4 W
NM/SM slot 1 Power consumption = 12.0 W
NM/SM slot 2 Power consumption = 21.4 W
Total System Power consumption is: 100.8 W
Environmental information last updated 00:00:20 ago
I believed the fan make a lot noise is Exhaust Left temperature because is the more high on temperature.
Do you know if i can config the speed on the fan to stop a lot noise?
Thx
04-01-2020 12:32 AM
sorry the model is 2951 and not 2911
04-01-2020 12:40 AM
04-02-2020 04:36 AM
Hello Daniel,
I hope you are doing well.
You have reached the Small business community.
Can you please address this topic here : https://community.cisco.com/t5/technology-and-support/ct-p/technology-support ?
Another option would be to contact our front line and open a case for assistance.
The telephone numbers can be found here : https://www.cisco.com/c/en/us/support/web/tsd-cisco-worldwide-contacts.html.
I wish you a great day !
