How can I log-in into the Cisco-ios Mode on my CVR100W Wireless-N VPN Router?
edwardzhouquan
Hi Everyone,
I am just quite confused about how to log-in into the Cisco-ios Mode on my CVR100W Wireless-N VPN Router.
I have updated the firmware to 1.0.1.19, as you can find it via ( http://software.cisco.com/download/release.html?mdfid=284758089&softwareid=282487380&release=1.0.1.19&relind=AVAILABLE&rellifecycle=&reltype=latest
As the official Administration Guide (http://www.cisco.com/en/US/docs/routers/csbr/cvr100w/administration/guide/CVR100W_AG_OL-26942_02.pdf
) told,  I can configure the router via my web-browser, just typed-in the address 192.168.1.1. However, it is a fixed web-based configuration UI. Many advanced functions do not allow me to access. For example, I cannot configure ipv6-ISATAP.
I am a CCNA-holder, and knows that Cisco is proud of its ios-platform.
So, can anyone help to tell that how can I configure my CVR100W Wireless-N VPN Router into an Cisco-ios Mode ?
Thank you!!!
7 Replies 7
vvijaysa
Hi Quan,
You have to login to the device using a Telnet/SSH client. Try downloading Putty (http://www.putty.org/). Then, you plug in your router's IP address and choose SSH or Telnet. Also, you can connect your router via a console cable (you may need a serial port on your PC). After you connect via console, choose Serial/COM instead of SSH/Telnet. You don't need to plugin the IP address in this case.
Hope this helps,
Vijay
Thank you Venkitachalam Vijay Sankar !
I have tried. But actually, the Telnet/SSH mode does not work, not only with Putty as you mentioned, but with Windows built-in CMD-Telnet window either. Also, my router has not any Serial/COM ports for me to configure.
Thank you again.
Sorry Quan,
I guess as they said below iOS mode is not supported for your CVR100W.
Vijay
mpyhala
Level 7
Level 7
Hi Quan,
The Cisco Small Business routers do not have CLI support. They can be managed from the web GUI only.
- Marty
Hi mpyhala,
What a pity!!
Is there any other ways, such as Factory Mode, to use CLI to configure?
Thanks!
Hi Quan,
If there is a "Factory Mode" it is Top Secret and I have never heard of anyone finding a way to access it. I think that someone would have found some way to access it if it was possible.
- Marty
David Harper
The CVR100W is not an IOS-based router, so there is no CLI available.  The smallest IOS-based router platforms available currently are the 800-series ISRs.
Cheers,
Dave.
