How can I open a specific port on RV345
Obiben
All I see is predefined options for services that don't tell me much. I don't see the added value of limiting to a set of predefined values you can't even see the underlying value for.
AlKor
Its easy.
1. Go to System Configuration ->Service Management
Press "+" for add new port. Enter app name, protocol, start port  № and end №App.PNG
Then press "Apply" button
2. Go to Firewall->Access Rules
Press "+" for add new rule.
Enter parameters and press "Apply" button.
Its all.
AlKor
Its easy.
Its all.
