Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
11513
Highlighted
Beginner
Re: Hi Genekurtz,
The RV340 is slated as the replacement for RV320 which is "end of sale".    How can we start reselling this product with such glaring issues.  Does Cisco read these posts?
Highlighted
Beginner
Re: Hi Genekurtz,
I'm disappointed that Cisco is unwilling to answer this themselves, but alas.
In the release notes for 1.0.01.18, there's this known issue:
A VLAN1 device management issue may happen during a direct firmware upgrade from version 1.0.0.33 to 1.0.01.18. where the GUI cannot be accessed from the LAN.
Workaround
If your device is running with firmware version 1.0.00.33, please first upgrade the firmware from 1.0.01.16 or 1.0.01.17. Then, continue to upgrade to version 1.0.01.18. This is because a new feature was introduced to enable/disable the device management per VLAN. A direct upgrade from 1.0.00.33 to 1.0.01.18 will make the GUI inaccessible if the VLAN1 address is other than 192.168.1.1/24.
Sure enough, on my RV340 I had done a direct upgrade as soon as I got it plugged in (as anyone would), and the "device management" box for VLAN1 was unchecked, and you couldn't click to enable it. Any change to the VLANS at all would completely disable the web GUI.
Downgrading to 1.0.00.33, then following the instructions to upgrade to 1.0.01.16 then 1.0.01.17 then 1.0.01.18 (by uploading images manually) shows the VLAN1 with device management enabled, and I am now able to change the IP without issue and still access the web portal. Hope this helps.
Highlighted
Beginner
Re: Hi Genekurtz,
good find.  Maybe I won't give up on this product.   Really would like to find a replacement for ASA and RV320s
Highlighted
Beginner
Re: Hi Genekurtz,
I also stuck here for quite a time. Now I have figured out an easier solution without downgrading.
1. Download current config. You will have an XML file including all the configs provided by RV router.
2. Replace all 192.168.1. to whatever you want, for example 172.16.1.
3. Upload the changed config back to the router.
After this, without rebooting, you can really login with the 172.16.1.1. Now you can save the current config for good.
Highlighted
Beginner
Re: Hi Genekurtz,
I had given up on the RV340 product but saw that Firmware Version 1.0.01.20 was available.  I upgraded to this version and the management interface issues are fixed.  I am currently retesting the product.
Hallelujah
Highlighted
Beginner
Re: Hi Genekurtz,
RV340 new IP address.  The answer. DO NOT upgrade firmware to the newest version (ends in 3.15) until after you have changed the ip address. You can update to the newest after it is saved.
You need to go into VLan. Add a vlan with an address you are not going to use. Change the bottom Lan settings so that each vlan has at least one lan. Always click apply then click save (floppy disk icon) then apply again. go back and change vlan 1 to what you want, apply, save, apply. Go back and get rid of the second vlan and change the lan under it back to vlan 1. Apply, save, apply.
You can upgrade to the second newest firmware first but not the newest. (you can install an older version if you already installed the newest firmware.)
I hope this helps. I don't remember every painful step but the newest firmware... .3.15 is faulty.
Highlighted
Beginner
Re: Hi Genekurtz,
The trick seems to be to tick off the checkbox for "Reset all configurations/setting to factory defaults" when upgrading the firmware.
After a boot, VLAN1 will have Device Management still grayed out, but now it's checked.
I tested this with firmware 1.0.03.15.
Diffing config xmls from before and after factory reset shows many different changes.
The important one to this issue is:
        <enable-management>true</enable-management>
which is added to
      <vlan-interface-settings xmlns="http://cisco.com/ns/ciscosb/vlan">
        <vlan-id>1</vlan-id>
So if you want to keep your settings you can just save your config, add the <enable-management>-key and import it back in, you'd think.
Magnus
Highlighted
Beginner
Re: Hi Genekurtz,
I've followed steps 1 & 2, but then for 3 when I try to access the router on that IP address it doesn't work. What am I missing?
Highlighted
Beginner
Beginner
Re: Hi Genekurtz,
I had a similar experience, but it was because I didn’t wait long enough for the router to fully reboot. My router took several minutes to come ready. Once I viewed the lights all indicating full operation, then I had no issue.
Highlighted
Beginner
Re: Hi Genekurtz,
Oh ok so I have to save the config and then reboot the router? I was just
changing it and then trying to access it without a reboot.
Highlighted
Beginner
Beginner
Re: Hi Genekurtz,
Yes, I believe all changes require a reboot. Particularly with anything to do with the IP configuration. Once you reboot, you must wait until the system has gone into stable operation again. Then you can try logging on. Let me know if that helps you?
Highlighted
Beginner
Re: Hi Genekurtz,
saving the config and rebooting allows me to log in going to 20.0.0.1, but
I am having a problem with step 4: 4. Once you have got the access on port
2, then change the IP address on vlan 1 to 10.0.0.1/24(10.x.x.x
subnet)->apply
once I change the IP address on VLAN 1 it tries to apply it and then just
'hangs'. i then can no longer get to the UI via 20.0.0.1. i just did a
reboot again since I wasn't able to save that change. any idea why this
would happen? it doesn't seem to want to let me change VLAN 1.
Highlighted
Re: Hi Genekurtz,
Hello Dear Friends at Cisco,
for a so so so simple step, you at Cisco really complicated things!
It would be so nice to just created a field on the LAN section to be able to just change the main Gateway IP address!
You truly complicated things!
Highlighted
Re: How to change LAN IP range on rv345
Please make sure you use the latest firmware ( 1.0.03.15) screenshot below is from that firmware.
Go to VLAN settings, click on VLAN1, click on the edit icon and a pop up will appear.
Change in the pop up the IP address settings.
Apply
Reconnect your PC to the router as the Ip address has changed.
Save your settings
Highlighted
Beginner
It looks like browser cookies must be cleaned before trying to reconnect to the new IP address.
My steps:
1. Change VLAN1 IP address
2. Apply
3. Do not reboot a router
4. Clean browser cookies
5. Connect to the new IP address
6. Save running configuration to the startup configuration
7. Reboot a router to test a new configuration
