08-25-2011 07:32 AM
Hi, I am using the RV220W with the latest firmware, I disabled all the four APs and also disabled the Radio, but the "Wireless" green light on the front panel still ON, why? How can I completely turn off the wireless?
Quoted from manual:
WIRELESS—The Wireless light is green when the wireless module is enabled. The light is off when the wireless module is disabled.
Moreover I tried to disable the "Radio" while enabled one AP, I found that I can still connect to that AP, so what is the Radio's Enable/Disable used for??
Thanks.
Raymond
08-26-2011 09:34 AM
Please help. Is it a bug??
Thanks.
08-27-2011 04:14 AM
Yeah it is kinda bugged, as you have to disable each wireless network first, then disable the radio.
Developers really need to make it that if you 'Disable the Radio' it actually goes and disables the radio chip, stupid really....
08-27-2011 09:02 AM
So the "Radio" setting is completely NOT working? I disabled the "Radio" while enabled one AP and I can still connect to that AP...
Another bug: Even I disabled all the four APs and the "Radio", but the "Wireless" green light on the front panel is still ON...
How come Cisco can release such a buggy firmware? Even cheap routers can do this better.
08-27-2011 06:48 PM
Yeah my wireless light is still on. So obviously the 'Turn Radio Off' setting does not work.
And yeah, the old Billion I upgraded from did a better job in plenty of places, just no VPN features, hence the upgrade (or possible downgrade lol)
08-28-2011 03:49 AM
There are a number of issues with the RV220W which should have been resolved by now but I guess we shall just have to wait.
I wish cisco would list the known issues they have via a bug list of some sorts.
08-28-2011 09:38 AM
Bug list from another forum member:
08-29-2011 12:38 AM
I've looked at the list but are these totally confirmed by Cisco since this is an unofficial site. Also there are no instructions on each bug of how to replicate the issue. without replication, bugs are near impossible to fix.
Now if Cisco would list the bugs themselves, that would have to be a better idea.
Known issues are listed in the Release Notes of the new 1.0.2.4 firmware
http://www.cisco.com/en/US/docs/routers/csbr/rv220w/release/notes/RV220W_Release_Notes_1.0.2.4.pdf
btw there is only 21 issues listed in the release notes. Buglist shows 15 more.
08-29-2011 03:43 AM
Cisco has been rather uncooperative in investigating the observed bugs to have them documented.
This tells more about Cisco than about the list !
08-29-2011 03:47 AM
Wow that's just sad on Cisco's behalf...
11-10-2011 05:13 AM
Joergen Thomson, I can see that you have the same thoughts like I do, I wish they could release a software that is stable and better then this.
I dont have the energi or time to report all flaus back to cisco, this product have taking to much of my time and frustration already. Thank you so much for all the time you spend to try get this product stable and hopefully a good product.
I have a costumer that have a webservice that is IP restricted, For now I have to define more then 93 policys openening for the same service because this doesnt handle address list and groups. And all the times I had to set it back to factory default becasue of HTTP Admin server stopped, VPN Problem, Firmware Upgrades, "Packet Loss" and so on takes alot of time becasue I need to reconfig policies back.
For now to they release a firmware is stable I have take this piece off the network and put the back a old Fortinet 60 box.
08-29-2011 03:54 AM
Added to the buglist in http://bugzilla.jth.net
Clicking Radio Disable in the Wireless -> Basic Settings page does not turn off the wireless radio.
I have confirmed this.
08-29-2011 09:05 AM
Another bug is even you disabled everything, the Wireless light on front panel is still ON.
08-29-2011 11:05 AM
Well, the LED staying on is probably a consequence of the radio not being turned off and not a separate bug.
08-30-2011 01:16 AM
But I already disabled all the Access Points, how come the Radio still ON??
