I'm trying to setup my RV 110w for internet access. The internet connection is over PPPoE however in the information provided by my ISPs it says the PPPoE connection needs to be configured to be tagged with Vlan id 7.
How can I configure this in the Cisco RV100w?
THanks
it should be same like below config (instead VLAN 1 you setup VLAN7)
RV110W is an old model router. As per the administration guide, VLAN tagging option on the WAN is not available on that router.
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv110w/administration/guide/rv110w_admin.pdf
