How to debrick a WRVS4400N V2 Router?
tcianflone
I've got a WRVS4400N V2 Router that just keeps rebooting itself. It powers up, the diag red LED stays lit, it gets part way through the boot process and reboots itself. I would like to try to reflash the device, but don't know if this is possible in the condition that it is in. Any ideas? Thanks!
jurodri3
Hello Mr. Cianflone,
Usually the red led flashing indicates a hardware issue. In that case, I would recommend you a factory reset and if the problem persist. Please contact our Cisco support center and open a case.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Diego Rodriguez
Cisco network engineer
Thank you.
What is the procedure to perform a factory reset please? Thanks!
hold the reset button for 20 sec and then release it.
