02-27-2021 07:57 PM
We are using rv130 to connect internet.
IPS offering internet connection via PPPOEv6 and IPV6 address.
WAN port can receive IPv4 and IPv6 address.
How can I config DHCPv6-pd ,so that on of my server on LAN can assign IPV6 address from ISP.
02-28-2021 12:53 AM
- Probably not supported the data sheet (https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/datasheet-c78-738909.html) , lists the following ipv6-features only :
IPv6 |
02-28-2021 02:56 AM
So. which product support DHCPv6-pd?
02-28-2021 03:34 AM
- My initial reply could be incorrect , have a look at this guide :
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv130w/admin_guide/en/rv130w_admin_en.pdf
Look for 'Prefix Delegation' with find in your browser and view the concerned paragraphs completely. Check if this can provide more insights.
M.
02-28-2021 05:11 AM - edited 02-28-2021 05:15 AM
Oh, I found it.
Sadly. My ISP provide IPv6 after PPOE dialup. and the option only affects WAN connection type is DHCPv6 mode.
When I set IPv6 wan DHCPv6 mode and Prefix Delegation enabled. WAN port can not get IPv6 address from ISP.
When I set IPv6 wan mode PPOE IPv6, then WAN port can get IPv6 address from ISP. but router can not prefix delegation IPv6 addresses to LAN network.
I need is after PPOE dialup , WAN port be assigned from ISP, and prefix delegation to my LAN.
I can not do that both. I remember rv130 support it some years before.
