How to "ALLOW" facebook access between 12pm and 1 pm ONLY RV042
247Serveradmin
I have been trying to resolve this issue with only allow facebook access throug the content filter between 12pm and 1 pm.  However The settings never seem to take.  Anyone know if this is a bug in the system?  If I start the filtering from 1300 to 1200 that should allow facebook to be accessible only on lunch.
Any suggestions?
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center.
Facebook is like the Mythical 3 Headed Dog Cerberus,
In order to kill it you have to cut off all three of its heads.
With Facebook, in order to manage it or completely block it, you have to know all of its different IPs that it uses.
Doing a little digging I found that the main facebook website has the following IP addresses:
www.facebook.com 69.63.176.12
www.facebook.com 69.63.176.13
www.facebook.com 69.63.176.14
www.facebook.com 204.15.20.25
www.facebook.com 204.15.20.26
www.facebook.com 69.63.176.11
then, doing some more digging, i've found the following IP address ranges that appear to be associated with facebook:
69.63.176.1-69.63.191.255
204.15.20.1-204.15.23.255
Good Luck.
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
Sorry to intrude but If I use SRP 527 how to configure the same thing to block FB only from 9 to 1 and 2 to 6?
Best Regards,
Mr. Simon Yee
Document Control
Budi Feed Sdn. Bhd.(827186-P)
Lot 11940, Jalan Perajurit 1,
Off Jalan Perajurit,
Kampung Tengah,
Telok Gong,
42000 Port Klang,
Selangor Darul Ehsan.
Tel :-- 603-3134 1081
Notice of Confidentiality:
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material.  Any review, re-transmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited.  If you received this in error, please contact the sender immediately by return electronic transmission and then immediately delete this transmission, including all attachments, without copying, distributing or disclosing same.
Best Regards, Mr. Simon Yee Document Control Budi Feed Sdn. Bhd.(827186-P) Lot 11940, Jalan Perajurit 1, Off Jalan Perajurit, Kampung Tengah, Telok Gong, 42000 Port Klang, Selangor Darul Ehsan. Tel :-- 603-3134 1081 Notice of Confidentiali
