I don't know if this is normal but I see many incoming connections, mainly from Google etc.
For example, why is Google making a connection from 172.194.38.129 to 192.168.2.2:4982 ?
The firewall on 192.168.2.2 is on but that is after the RV042 of course.
I am sure that there is a simple answer for this.
Apr 6 19:03:52 2012 | Connection Accepted | UDP 208.67.222.222:53->192.168.2.2:64086 on eth0 |
Apr 6 19:03:53 2012 | Connection Accepted | UDP 208.67.222.222:53->192.168.2.2:55580 on eth0 |
Apr 6 19:03:53 2012 | Connection Accepted | TCP 173.194.38.137:80->192.168.2.2:4980 on eth0 |
Apr 6 19:03:53 2012 | Connection Accepted | UDP 208.67.222.222:53->192.168.2.2:57151 on eth0 |
Apr 6 19:03:53 2012 | Connection Accepted | UDP 208.67.222.222:53->192.168.2.2:58089 on eth0 |
Apr 6 19:03:53 2012 | Connection Accepted | TCP 173.194.38.129:80->192.168.2.2:4982 on eth0 |
Apr 6 19:03:54 2012 | Connection Accepted | TCP 173.194.38.129:80->192.168.2.2:4982 on eth0 |
Apr 6 19:04:13 2012 | Connection Accepted | TCP 72.14.203.125:443->192.168.2.2:1087 on eth0 |
Apr 6 19:04:22 2012 | Connection Accepted | TCP 157.55.130.144:40031->192.168.2.2:4700 on eth0 |
Apr 6 19:04:30 2012 | Connection Accepted | TCP 213.146.189.206:12350->192.168.2.2:4705 on eth0 |
Thanks in advance
