IP forwarding problem
Dear all,
I write on this community support to ask you your help to made a special configuration.
I have a network of 3 cisco 2611XM routeurs connected on the same network with their interfaces f0/0.
On the f0/1 of the 3 routers I have some networks element which have the same IP addresses.
Here is a scheme :
10.1.1.1/24 ------ f0/0 RTR1 f0/1 ------- 1.0.1.5/8 ---------- Network element  with IP 1.0.1.0/8.
                         Lo0 10.255.255.1
10.1.1.2/24 ------ f0/0 RTR2 f0/1 ------- 1.0.1.5/8 ---------- Network element  with IP 1.0.1.0/8.
                         Lo0 10.255.255.2
10.1.1.3/24 ------ f0/0 RTR3 f0/1 ------- 1.0.1.5/8 ---------- Network element  with IP 1.0.1.0/8.
                         Lo0 10.255.255.3
What I want is the next thing :
When I do a telnet on the f0/0 of a router I want a telnet access to the network element with IP 1.0.1.0
When I do a telnet on the Lo0 of a router I want a telnet access on the router itself.
All other type of traffic is authorized.
Thanks for your help.
Jean-Yves
Hello Mr. Yves,
Thank you for your question.
However, the Small Business Support Community is limited to Cisco Small Business Products and the 2611XM router is an Enterprise level product.
You might consider to ask this question at Enterprise forum to get a better response.
https://supportforums.cisco.com/index.jspa
Best regards,
Diego Rodriguez
Cisco Small Business Community Engineer
Hello Mr. Yves,
Best regards,
Diego Rodriguez
I create a new question in an Enterprise forum.
Br,
Jean-Yves ANDREOLETTI
