Hi, I had another question on using IpSec over Iphone with IOS10. I had 2 routers RV320 and RV325 which I need to VPN to these routers for data exchange. Whenever I tried to connect to the routers by VPN, a connection could not be established (especially when using mobile network) unless I reboot the router. After a reboot I can log in within a few hours.
Is there any solution?
Chris Poon
