I have a few questions regarding IPSEC, DynDNS, accessing the router externally, and using those features on the following models (all models are of the latest firmware):
RV120W (WAN IP 12.20.20.20; LAN 10.20.20.1 255.255.252.0)
RVS4000 (WAN IP 12.2.2.2; LAN 10.2.2.0 255.255.255.0)
WRV4400N (WAN IP 12.3.3.3; LAN 10.3.3.0 255.255.255.0; SSID WRV4400N WPA2)
WRV200 (WAN IP 12.4.4.4; LAN 10.4.4.0 255.255.255.0; SSID WRV200 WPA2)
WRV210 (WAN IP 12.5.5.5; LAN 10.5.5.0 255.255.255.0; SSID WRV210 WPA2)
All devices have preprogrammed IPSEC tunnels to each other devices. All also have Dyndns on them (although they are static IP but just in case).
The following questions:
(1) I've noticed that the RVS4000 and the RV120W will have consistent tunnel up but i don't see any traffic going through (ping 10.2.2.1 from RV120W is not successful).
(2) If i set RVS4000's tunnel property (Local Group) at IP+FQDN, the tunnel will not be successful. If i set it to IP only, tunnel comes up but again the problem is as stated number 1
(3) I have noticed that tunnel of RVS4000 and WRV200 is successful. Again with RVS4000's properties similar to number 2 (IP only).
(4) I have noticed that i can not remotely access the management feature of WRV200, WRV210, WRV4400N, and the RV120W. But i can remotely access http://12.2.2.1:8080 (that's the port i have assigned). I wonder if its related to wireless?
(5) I wanted to register these units for support, where do i begin with that?
Thanks in advance.
